Suspension Questions...
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
hey guys... I just got my SPL suspension stuff... First off, JEEZ this stuff is beefy... Got front and rear upper adjustables and the tension rods.....
I got this stuff lightly used... On the tension rods and rear links, the bearings come off fairly easy.. Should I put some grease in them before I install? The little bearing things can be seperated.....
Alos, how do I adjust them... The tension rods, i think i just loosen the 2 outer nuts... I looked at the directions on SPL..... I think thats how you do it but I want to verify.....
Also, im running this on my Q45.. What would you guys recommend for alignment specs... I may auto cross this but Id like to keep this as a fairly streetable setup..... IM also running staggered wheels/tires so i cant rotate.....
TIA!!!!!!!
Exar-Kun
Car: 2005 350Z
Wes, the bushings in the multi link aprts should all be pillow ball (heim joint), and shouldn't separate..they're permanently lubed teflon units IIRC. No need to grease them or anything (in fact it will make them perform worse..)
And yes, you loosed the two lock nuts, twist the center shaft to adjust and lock it in place...
Alignment specs...do you have a front camber adjusment? Is this for mostly street, autocross, etc?
-Chet
elwesso
2007 BMW M Coupe
Yeah i have front camber arms... This is on my Q45 so it goes thru tires fast enough as it is... Something that will handle good and my tires will still last.
Exar-Kun
Car: 2005 350Z
well, the rear multilink has much more camber gain under compression/loading than the front I should think...does the Q45 ahve a double wishbone front or a mcpherson design?
Also, what does the car tend to drive like? Lift throttle over or understeer, etc?
-Chet
elwesso
2007 BMW M Coupe
The suspension is basically the Z32 suspension for all benefits and purposes.. Thats why im using all Z32 things...
If anything its fairly understeerish.. Even with my bigger rear sway bar it still likes to understeer. With the 225 front tires and 265 rear tires going on thats not going to help at all.....
elwesso
2007 BMW M Coupe
Anyone? bueller?
im trying to get this installed sometime in the next couple days and then will take it to an alignment rack soonafter
Exar-Kun
Car: 2005 350Z
Wes, IM me and I'll be more than happy to chat with you about it, pros/cons, etc...
-Chet
