silencer.1 »
https://forums.nicoclub.com/silencer-1-u16260.html
Tue May 11, 2004 1:22 pm
First off, hello to everyone! I'm new to the board and recently bought a '90 240sx. I got it relatively cheap in hopes of making it my project vehicle. It's all stock at the moment other than the replacement speakers in the doors.
The struts on the rear are worn out so I'm going to be replacing them within the next week or so. I'm currently contemplating a couple of solutions to this. The first solution is the cheapest and simpest, just go to autozone, buy stock replacements and bolt them up. The second is to get a little more involved, buy aftermarket struts all around and a set of lowering springs to drop the car about an inch or so. I'd also get a set of sway bars while I'm at it. This is definately more expensive but I think the gain in handling would be worth it in the long run. I plan on having this car for a number of years and doing extensive work to turn it into a worthwhile drifting vehicle yet stay away from the rice crap.
As an after thought, if I do just do a simple stock strut replacement, I'll still have about $800 to put into other areas immediately. I plan on changing the engine out from the ka24e to sr20det eventually so I don't want to spend money on frivelous engine enhancments at the moment since they are going to be negated in a year or so when I replace the engine. Any suggestions would be appreciated.
Thanks in advance for your opinions.
