PhoebusApollo wrote:Ok, so let me see if I understand this correctly. The smaller the diameter of the bars, the less force they are exerting on the tires. As I picture it in my mind, the tortional force they exert reverses any camber on the wheel, bringing the bottom lip of the wheel in towards the center of the car, reducing contact patch and causing the tires to slip sooner? Therefore the less amount of force the bar exerts the more cambered a wheel will be, increasing (to a point) the amount of contact patch in a turn and increasing grip? And the suspension allows for travel in a wheel in an up/down motion only, keeping the tire on the ground as much as possible? So if I want maximum grip and a soft ride, I would want a soft anti sway bar, and a high/normal ride height with a small amount of rebound. Do I have it? Or am I retarded?
A soft rebound along with a high amount of travel length would lend towards a "softer" suspension feel as Dennis (Q45tech) has outlined before.
What I would suggest to you would be to get a moderate stroke, using a soft compression in the rear (to allow throttle input to take effect quickly, and change weight faster), and keep the rebound settings hard to allow you to re-transfer any resulting oversteer from the weight shift. Use a high spring rate (like 7.0 kgf/mm - 8 kgf/mm) in the rear with a 250mm spring.
As for the front a solid 10 kgf/mm 200mm spring or 225mm spring along with slightly harder compression, and a moderate rebound would work well.
For the roll bars... I'd stick with a small diameter, this is my personal preference. The spring rate should accomodate most of the travel and roll resistance. If the car suffers from excessive roll, then more than likely the car is lowered too much causing the roll center to be out of spec. Reworked lower control arms can fix that to some extent, but for the most part 240s do not like to be slammed.
Tires are by far the best investment you can do towards a car's handling. No matter the amount of weight tuning you do, or modding the suspension geometry, you're still limited by the amount of grip the tire can give.
TiresSuspensionCornerweightAlignmentRoad Testing (heat, pressure, etc.)Recalibration of Alignment
BTW, AFAIK the sway bar only effects the roll resistance of the car by tie-ing in the lower arms with a rigid bar. It effectively adds progressive spring rate via tension. Therefor the only effect it has on camber is the reduced amount of suspension bump. So from there, based on your static camber you can deduce if it is reducing your contact patch. If thats the case you need to remove static negative camber from the rear or deminish the amount of bump.
