Suspension question
All things Altima Coupe.
brando1
Car: 2010 Altima 2.5 coupe
Whats up fellas?
So i've been researching different springs and such for my suspension, i'm just wondering if i do go ahead and purchase new set of springs would i have to change my bearings or anything affiliated with the suspension?
Mind you i'm an everyday driver averaging 60miles a day so i don't need to go low especially with bs construction and constant bumps. I have a 10' A/C if that helps at all (52k miles)
YoungCoupe
Car: 2011 Altima Coupe 2.5s Metallic slate
No you won't have to change anything. Unless your struts are going to go out soon, in which case it'd be a good idea to get that done at the same time.
brando1
No they are fine, I had them checked at my last oil change. Thanks for the info
