suspension question
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
so i know the springs are stiffer on the J30t than the J30....my question is would the J30t springs fit on the J30???not really much of an upgrade but ive recently gotten a few calls from 3 local junkyards that have 5 Js available to pick off....i went and looked and 3 of them are in GREAT shape....the only reason they were junked was because the transmission went out and they didnt want to get them fixed...anyways any info would be great...
yodawill2000
Car: 94 Infiniti J30
Don't know the answer but I sure wish there were more J's in the yards out here !!
kbflip02
2006 Infiniti G35x
yodawill2000 wrote:Don't know the answer but I sure wish there were more J's in the yards out here !!
what did you need my little green friend im sure we can work something out
Q45tech
Why would you believe that there is a difference in spring rates.Historically Nissan has used differences is sway bar rates [softer front and stiffer rear] on the t models [G, J, Q].
Nissan selects spring stiffness to match the fore aft weight ratios.
kbflip02
2006 Infiniti G35x
Q45tech wrote:Why would you believe that there is a difference in spring rates.Historically Nissan has used differences is sway bar rates [softer front and stiffer rear] on the t models [G, J, Q].
thank you for clearing that up for me
yodawill2000
kbflip02 wrote:what did you need my little green friend im sure we can work something out
Nothing really at the moment ,,Other than the lower engine cover.But that would be a hassle to ship.Mines in pretty bad shape.
kbflip02
2006 Infiniti G35x
how far are you from austin????i will be dropping the K off there sometime early jan(hopefull) to for the VH swap....if you want my old one ill let the shop know that youll be coming by to pick the old one up off my VG30DE...also i wont have anymore use for my JWT cams or pulleys either...that is if your interested....if not im sure once we pull the old motor i can convince nala to buy them off me...lol
