One on each side from the front, the others from the trunk. Is the easiest way. Also helps to have a ratcheting wrench instead of a bulky ratchet and socket.Coolwhip wrote:you can access the 2 top 12mm nuts by dropping the top part of your rear seat, and by access through the trunk.
Ratcheting wrench with a swivel head ownz in this sport as well.jspec603 wrote:
