Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Mar 27, 2003 11:32 am
The usual difference in touring vs standard in Nissan is sway bars........Springs are calculated for vehicle weight [the correct value is a narrow range based on weight and wheel base distance to comply with road seams. Lux cars have under damped shocks, performance cars have ideal damped shocks, and aftermarket have over damped shocks.
For every 1.0 inch a suspension is lower by springs the springs have to be 1x1/7 [14-16%] stiffer. Generally Tokico blues are 20% stiffer in compression and rebound when brand new. By 25-30-35,000 miles they are about equal to new oem shocks. The rears go first since the undilating rear moves 145% as much [stroke distance] as the front per mile as the front sway bar acts as a partial spring.....limiting front up and down movement [plus 55% of weight is here].
Most suspensions are designed to be comfotable at 55-65 mph on smooth highways potholes are never considered in a design other than by bump stops [rubber isolators] which keep the shock tower front shooting thru the hood.
