suspension question......might sound stupid but ohh well.
DrifterBoy240
Car: 1991 nissan 240sx
okay so the other night was driven my car messing with the dampers and front camber. and i went to go take a corner nice and smooth and grip run it and NOT drift it, as i took the car around the corner it had wanted to step out or slide out and drift. i have my dampers setup pretty stiff.
i think if i get a rear camber kit and some sway-bars will that help out for it grip. so some one with some knowledge about suspension point me in the right direction.
and i dont have much power but a slightly moded KA with a diff and coilovers.
Spectre
Car: 1995 Nissan 240SX SE
I moved your thread. Hopefully you'll get the response you want in here.
gumby74
Yes. try about two degrees neg out back with 1/8 toe in. What kind/ size tires are you running?
gumby74
Also, if your dampers are adjustable, go soft up front 2 degrees neg. camber and 0 toe. Just how adjustable are you at present?
DrifterBoy240
up front i have toe, camber, shocks adjustabliity. out back i virtually have the same thing i juts dont have and RUCA's but i will have some soon. and my tire size is 205/60/15 all the way around.
thanks spectre, forgot there was a suspension/brakes forum.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Alignment settings are a great place to start to dial your car in. I suggest this setup if you're having some oversteer issues:
Front:-2.5* Camber0* toeStock Caster
Rear:-1.5* Camber1* toe in
Until you get your alignment, try softening up your dampers, especially in the rear. People often underestimate the effect that proper damper settings will have on a car's behavior! A damper that is too soft will allow the wheel to "oscillate" over the road surface, even after it has experienced a bump -- this will cause a loss in traction and predictability as the vertical force (and therefore the lateral force) on the tire fluctuates with the "bouncing" motion you experience with an underdamped setup. However, setting your dampers as stiff as possible is not the correct remedy. Overly stiff dampers do not allow the wheels to return from their bump positions quickly enough -- this causes the wheel to "skip" over road imperfections, reducing your traction.
Soften your dampers a bit, and dial in your alignment.
DrifterBoy240
thanks amoeassassin when i am able to get my friends track side alighnment tools i will go ahead do that but until then i will be in a lighter terms S.O.L
but i guess what i really want is to be able to grip and drift the car i want a nice dual setup kinda but grip is more of what i want and the drift will come with speed.
DrifterBoy240
will lowering it make any differance in handleing? i can still go about 1/2in. in the rear lower and about 1in. in the front. but then agian i will have to reset all my settings again to like camber and toe.
nismofly
Car: 89 Nissan 240SX Hatch
depends how low you are already, but since youre talking about maxing out coilovers id say youre already past optimum handling and youre only going to make it worse by going lower
DrifterBoy240
well i have megan racing coilovers (track series if you need to know) and i just pretty much juts slaped them on and just mad sure that the car was at the same height all around.
nismofly
yep i can almost guarantee youre already too low for optimum handling
going lower than where you are now is just for looks
DrifterBoy240
okay thanks for the info.
SmithSR
Car: 240sx
Are you overlooking your tires? Greatest gains / failures are at the friction points.
DrifterBoy240
yea quite possibly, i will need tires soon all i got was something that would last me through my last winter here in WI and this weekend it is off to good old mississippi. i will get some decent tires after i move, any sugestions on tires? im only running a KA with intake, cams, full exhaust and a diff. so i dont think i need anything to crazy because i do still want to be able to drift the car on occasion.
nismofly
hankook rs2s
get spare tires for drifting
