The megan racing coilovers do have one issue, but I am not sure it is as big of a deal as I thought it was at first when I looked at them. Here is a quote from Megan racing about the coilovers
"These dampers are NOT a Direct Bolt-On, however, because you need to Re-Use your OEM front spindles. We did this to maintain a lower cost for the enthusiast, as the OEM spindles are perfectly able to be reused in most cases. The operation is simple and most shops that have the ability to weld using either a MIG or TIG welder can complete the operation in usually under an hour."
"After removing your front Shock casings with the spindles, mark off 40mm from the top of the spindle base and cut. Once you have the spindles with 40mm of tubing pertruding from them, simply slide the Megan Casings over the shock casings until they are butted up against the spindle casting, and simply weld COMPLETELY around the casing with either a MIG or TIG welder (NOT AN ARC WELDER!!!). Once this is done, simlpy screw on the bottom bracket onto the suspension system and you are ready to go reassemble your front suspension."
Can anyone clarify this? would like to hear from someone who knows the Q45 suspension.... does this seem reasonable?
Thanks Again, this site has been LOTS of help... my car is starting to turn a new leaf
