Suspension project
plainzwalker
Since I've been informed that there is more to the suspension then just struts/coils (no flaming please, I am still learning here), I decided I will finish this part out before I continue with any of my next projects.
Here is my shopping list so far (all ordered through SPL):
SPL solid subframe bushings 1 SPL v2 tension rods S13 Color: Black 1 SPL pro tie rod ends S13/S14 1 Z32 front tie rods 1 SPL pro rear upper arms S13/Z32 1
(Nismo struts/RS*R coils already installed)
(edit)This is a weekend (non rainy/snowing) and drag/track car(/edit)
Is there anything else that I might be missing, or would be recommended to replace while I'm doing these? With the solid aluminum bushings there is no need for collars correct?
thanks
(one last question, and will also ask in the local forums, but would anyone in the MD/DC/VA/southern PA area with a garage/work area and a free Saturday/Sunday be willing to help me out with this install? I'd be willing to supply food, beverages (both adult and non adult) and a monetary form of thank you for the assistance/teaching )
yokota180sx
Car: 1997 Stagea RS4, r34 front
LOL at drag/track car
get your prioroties straight and ill help you
plainzwalker
yokota180sx wrote:LOL at drag/track car
Okay, how about these priorities.
I plan on driving on weekends when it isn't/hasn't been raining/snowing.
I plan on taking it to the drag strip on weekends.
I plan on trying out time attack events (track).
So if wanting to do those 3 things is impossible, or doing one but not the others, fine. My car, my plans. I just asked for opinions/suggestions. I didn't ask for jokes. If you were to follow my prior post before starting this thread you will notice that I am trying to LEARN.
So like mothers always say (or should be saying), if you don't have anything nice to say, then don't say anything at all.
240DRFT
add maybe sway bars and strut bars. and ya with the solid bushings you dont use collars
plainzwalker
240DRFT wrote:add maybe sway bars and strut bars. and ya with the solid bushings you dont use collars
Thank you, I already have strut bars, not sure what type.
I'll look into the sway bars and find a decent pair.
Thanks
yokota180sx
you cnat have car set up well doing drag and trackpic one or the other
or buy a few differnt types of springs for hte front and rear
You cant have a well performing track car, and a drag car at the same time
spring rates are too high for good track handling and too low for good drag car
How about you search and you wont get these remarks
nismofly
Car: 89 Nissan 240SX Hatch
nice wheel and tire combo, critical
also werd to sways and stb's
setup your car for track if you just plan on dragging it every so often, itll be far more fun as a weekend street car that way
plainzwalker
nismofly wrote:nice wheel and tire combo, critical
I'm looking at 17x8 wheels when I get around to doing the 5 lug conversion.
I'm not sure when I'll try taking my car to a track, it's something I definitely want to try/do though. As for drag, as soon as the local strips start opening up in the spring I'll be there.
I'm not trying to be the next John Force or Schumacher, just trying to what I've always wanted.
So before I start ordering parts, I'll take a look into recommendations for track then.
Thanks for the input.
nismofly
the stuff you listed plus a few more things like the ones i listed are basically the core chassis mods of a full track car...stick to those for now though because theyre good parts to learn setup with, you can go crazier later on if you want
plainzwalker
nismofly wrote:the stuff you listed plus a few more things like the ones i listed are basically the core chassis mods of a full track car...stick to those for now though because theyre good parts to learn setup with, you can go crazier later on if you want
Okay, I'll start with these then. I have a place where I can install them, but I am not quite confident to do them myself yet, so I now I just need to find someone who can help me out.
One last question, besides from the SPL bushing set are there any other bushing that I would want to replace while I'm at it?
(edit) Should I go ahead and get a master set of Energy Suspension bushings while I am at it? Or are these essentially the same thing? I'm a little confused after reading a couple different posts. Thanks (/edit)
Modified by plainzwalker at 4:42 AM 1/24/2007
yokota180sx
if you cant install simple stuff liek that
you CANT do energy suspension kits
plainzwalker
yokota180sx wrote:if you cant install simple stuff liek that
plainzwalker wrote:(one last question, and will also ask in the local forums, but would anyone in the MD/DC/VA/southern PA area with a garage/work area and a free Saturday/Sunday be willing to help me out with this install? I'd be willing to supply food, beverages (both adult and non adult) and a monetary form of thank you for the assistance/teaching )
Once again. I am trying to LEARN. Last time I checked there are 2 ways to learn, trial and error (learn from your mistakes) and someone teaching you.
I have no problem trying this myself, but I'd rather have someone with some experience with me to give pointers and help out when needed.
Are you posting just to get your post count up or something? Seriously now, out of 3 posts you gave me 1 semi helpful hint/tip. The other 2 have be criticizing me over stuff that if you just read a little more and thought before you typed you would understand what is going on. Maybe I just need to go else where from now on.
Besides what is defined as simple to you or someone who has been doing this for a long time is different to someone who is trying to learn. Brake pads/rotors/drums/shoes are easy to me, oil changes are easy, hell even putting tires on wheels and balancing them is easy to me. But that is child's play to a lot of people. I got this car to learn.
yokota180sx
no im posting becuase ive done itI replaced all the bushigns on another car, and its a 2 or 3 day job depending ont eh kit you get. Requires a large amount of specialty tools
nothign against you, its just a PITA to do it
but on the flip side, if you take your whels off, look at your new arms, and look at the stock ones, it will all be like a lightbulb cgoing off. sooooo simple
plainzwalker
yokota180sx wrote:no im posting becuase ive done itI replaced all the bushigns on another car, and its a 2 or 3 day job depending ont eh kit you get. Requires a large amount of specialty tools
Then why couldn't you say something like that to begin with instead of trying to make look like I'm an idiot. I'll be the first to admit that I don't know a whole lot, but I am willing to learn.
I just talked to a guy on the phone and he recommended just doing collars instead of replacing the whole bushing since thats what he uses. However, since he mainly does drifting, would collars be good for what I want to do or is this just a cheap fix?
yokota180sx
I use KSP engineering aluminum subframe collars
they eliminated 80 % of wheel hop that i incurred, and now i only get it on certain types of surfaces.
plainzwalker
yokota180sx wrote:I use KSP engineering aluminum subframe collars
Wow, okay... I tried finding these collars but I can't seem to find them anywhere, in another thread you said you used ATTAIN KSP bushings, is KSP the model/style?
Thanks
yokota180sx
wwll KSP is the shop
ATTAIN is their branding line
http://www.ksp-eng.co.jp/ATTAIN/index.html
its a japanese company, i paid 120 for mine, you can get them for half taht in teh states
silnismo
+1 for sway bars, suspension technigue are pretty cheap and comes with everything u need. not so thick though.
i have cuscos, yummm beefy.
nismofly
ST arent adjustable so they really arent worth it...sway bars should really be used for tuning under and oversteer, not roll prevention
AmoebAssassin
Car: 1991 Base fastback 5spd, black
nismofly wrote:ST arent adjustable so they really arent worth it...sway bars should really be used for tuning under and oversteer, not roll prevention
While this is true, S13s do benefit from body roll prevention -- the macphereson strut fronts deliver pretty bad camber gain and have horrible roll center migration characteristics.
