suspension problems
S13JDM
Car: 1989 s13 240sx
hey everyone i got another question. i replaced my springs with some knock off teins and i replaced my shocks with kyb gr2s. i also got 30mm front tension rods and rear upper control arms.my question is when i look at my car from behind it looks like its leanin to the left.i measured the wheel gap on all 4 and its higher on the right side.does anyone know what that could be from and what would be a solution to this problem.any help would be great.thanks!
Chris28
Car: 92 s13 KA-T
Make sure you put everything back how it came out. Maybe you have your top hat pointing the wrong direction? Also measure the springs, if they are knock-off's then they could be different lengths lol.
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Take the car to an alignment shop and have them set the toe and camber on all four wheels. That is the only suggestion I have unless you have a manual camber adjustment tool. But either way, the proper way to set up the RUCA's for camber is on with an alignment.
