suspension problems on f50
hemhem71
Car: 2002 q45
I have a 02 q45 Ive had for about a 18 months car has gave me nothing but problems it started with the rear suspension bottoming out so I took it in to the dealer and replaced the rear springs then i the shocks and struts and still have the same problem.And I still hear a clunking noise coming from the front of the car when going over speed humps or just hitting little bumps.Then I switched out the oem 17"s to oem 18 alloy and my tire pressure light comes on after thirty miles or so and wont read pressure.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
So tell us about your tension rod bearings.
Presume you replaced all the rubber in back when you replaced the shocks?
Wheels have transmitters I believe for tire pressure montior. Dealer should have moved them over from the old to the new wheels and registered them with the on board computer.
hemhem71
Car: 2002 q45
what tension rod bearings are you referring to?I did not replace any rubber just back shocks and front struts. I didn't know about anything else.Does the dealer only have access to the board computer or is there another way I can do it?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The only ones in front.
If he didn't replace the rubber bumpstops/shock covers or the front strut bearings, he didn't do a complete job.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
BUSHINGS! NOT BEARINGS (tension rods)
Anyway, your problem could also be related to some sway bar end linksin the front, thats also pretty common. I wouldnt think that bushings would be shot that bad yet... After 5 years they are compromised but i cant think theyd be done for.
