Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Fri Jul 20, 2007 1:55 am
Amother alignment is a waste of $60. Wait until you get the upper links and tension rod bushings on.
Spend it on new upper links (If you plan on lowering the car, but the adjustable upper links).
Buy the tension rod bushings or whole new tension rods.
Then, when you get these replaced, have the alignment done, and tell the guy to set the toe-in to the minimum the book says is acceptible. This will help with inside tire wear.
The Pilot Sprots are a great tire, and should not feather as bad as cheap tires, but it sure hurts when you spend that kind of money on rubber, to see it eaten up in 10,000 miles...
