Florida240sx »
https://forums.nicoclub.com/florida240sx-u17691.html
Mon Jun 07, 2010 12:41 am
Is it a thump in just one rear side or both? Are the springs set correctly? the little groove springs may rotate if not, but should of happened within first time of driving. So are all the bolts tight? Can you take a pic.
There isn't much assembly here. 2 lower mount bolt and 3 upper then 1 bolt for the shock. Maybe brake related? Calipers on tight or is your wheel loose? Running spacers?
Something you unhooked is not back right.
How bad is the thump? I have that set-up n ym car and it was nice and stiff and always wanted to kick out and slide, but cruising it was perfectly fine and at moderate speeds
