hospitalbuilder »
https://forums.nicoclub.com/hospitalbuilder-u93818.html
Tue Feb 10, 2009 9:06 am
I had a similar problem and changed out the struts in the front. My car would vibrate significantly whenever I hit any bump at high speeds (driving in the interstate highways here in Denver was a real dream). My understanding is that the springs want to rebound and continue bouncing after a bump and the shocks prevent that, but when they go bad they don't prevent the spring from rebounding which was the shaking I was feeling. Depending on your mileage and usage (ever have the front wheels under water?) you may also want to repack the front bearings. That made a difference in my ride quality (but I was well north of 100K).
You said your front shocks were still good, but if the rears went bad, it may be time for the fronts as well. Anyway, that is what worked for me. Good luck to you.
