navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Tue Dec 27, 2005 7:40 pm
they arnt adjustable "coil over" springs are they? if they are, then i pretty much guarentee thats your problem. otherwise, bent or broken arms could be your culprit. if the car is pulling to the right, then somthing is causing your wheels to not all point in the same direction, hence alignment is off by alot. do that as soon as you can, see if that fixes it. also, make sure you get the alignment specs and your car's specs from the shop and post those up
