suspension problem ASAP!
KSee777
OK... I'll start from the beginning... I started hearing a "pop" sound when I turn the steering wheel. I hear it when driving and sitting still. 3 months later, I find time to check what was up. As I was loosening the 3 bolts ontop of the shocks, one of them would not come off. I ended up taking a chisle and split the nut in half. I find out that the bolt was no longer securely attached to the top hat. Sooo, now my questions.
1) Could the tension rod be at fault? I know I need to change it and am looking for a good price on one. I was wonder if since it is old, the whole suspension moves around and causes the bolt to come loose.
2) From the above pic, there's an arrow on the top hat.( circled in red) Where is it suppose to point? (I'm assuming out)
3) Lastly, on the top hat, there is a notch where the spring sits. Is there a reason there's a notch there?
Sorry for the long post and Thanks for reading it!
p00t
Sorry i cant see the picks. Links dont work :(
If you want to see how all the parts go together check out the spring/shock change walkthrough:
http://www.nissaninfiniticlub....33310
KSee777
pics fixed! :help :help :help
Nismo_Freak
Car: 89 Nissan 240SX
The poping noise you heard is prolly your sway bar endlinks.
KSee777
why would my endlinks "pop"?
KSee777
:help:
KSee777
No one on this board knows the answer to my questions?!?! man...
240marcuSX
Car: E34 525i
E46 M3
sounds like a good time to get some new struts, camber plates, and tc rods..... thats quite an original problem you got there, maybe your struts were just deffective? sorry Im of no more help :(
lbrowne
I have a clunk in my front nd usually when I have the wheel fully cranked to either one side, coupled with hitting a dip or bump (kinda like if you're turning around in the street, and possibly go over one of those soft curbs of a sidewalk, the kind you can safely drive up onto.)
I have new front struts, new swaybar bushings, new TC Rods.
Thing is, when I got the car the front pass. strut was so bad I wouldn't be able to tell if this clunking was there before I put the new parts on or not. So now I'm thinkin ball joint??
Its quite possible that my strut tower mounts are gone....but in your pic I thought that notch was where the end of the spring was suppose to end....I think.
no expert here sorry :(
ricebike
2002 Quest
2005 Altima
sorry if this is late: i'm doin a search on TC rods B4 I post my own ?
A. to #3) the notch is there so u can orient the whole assembly to the body of the car correctly... my 89 FSM says the cutouts should be facing toward the inner side of the vehicle.
