xswamperx »
https://forums.nicoclub.com/xswamperx-u168427.html
Wed Jun 11, 2014 4:52 pm
Hey Leo, I don't know to what degree your tow in is, but if its noticeable to your eyes you can get a camber alignment kit which is really easy to instal and cost you around 30bux roughly to do it yourself. Generally if you lift your Pathi, (I don't know if yours is), but if it is id really recommend it. Get it to where you want it to be, then take it down and have the alignment done.
If I were to say what is most likely that needs replacing which has bushings, is the connector rod which ties into the front stabilizer bar and strut mount. Those seem to wear out more than anything else on the front end. Those again are real easy as well and pretty cheap to do yourself. But check them out first you may not need to replace them at all. The ball joints don't usually go bad, but they can and can be somewhat of a b*tch to get in. you just need to be patient with them if and when you install them.
As far as your cv's are concerned you need to get some dust boots for those things asap. And don't get the split boots as they're complete crap, but can get you out of a jam if your 4 wheelin in the back woods. They're only a temporary fix. If your cv is somehow still in decent condition, then get the good boots, pull the cv's and install them.
