suspension overhaul help
nwmrkt
Car: S13
Hey, I would like to do a whole complete suspension overhaul on my s13 meaning replacing a bunch of the old oem parts. So I was wondering if you guys could help me make a list of just the part names, no brands in specific.so...
rear subframe bushingsrucas...etc.
I dont really know all of them right now so thats why im asking. (im not a 240sx noob or anything like that , just need some help on this particular subject)
Thanks alot!
180fan
Car: 89 fastback
Energy Suspension master bushing kit. this will probably impact your driving experience more than most other suspension parts.
Inspect your subframe bushings. Unless you're a complete masochist, I'd suggest using collars. The new bushings are probably the best way to go, but collars are pretty sufficient. Reason I suggest looking at the collars first is if you've ever tried mounting back up a rear subframe, you'd understand why I wouldn't suggest pulling the subframe.
Unless you're lowered and have camber issues, don't sweat the ruca and toe rods just yet. You're better off checking out your wheel bearings and ball joints on the front and rear lca's.
then I'd look into the struts and depending on how far your ride gets lowered, then start looking into a ruca/toe link package.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Front:Lower control armsInner tie rodsOuter tie rodsT/C rodsRear:Upper control armsLower control armsTraction linksToe rodsSubframe collars/solid bushings/poly bushings, etc.
nwmrkt
Car: S13
thanks guys, appreciate the help!
