EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Tue Mar 06, 2018 10:36 am
Does your steering wheel jiggle a little as you drive and maybe sometimes as you brake?
Mine did/does and I did come to isolate not only the stabilizer links but the stabilizer bar bushings as well. Almost 200,000 miles on the odo.
The car is still on jackstands as I refresh front and rear components, but as you can imagine suspension noise can be quite a rabbit hole of real issues that need addressed, but aren't quite the main issue you went in for.
Good luck, and let us share updates
