Suspension Noise
Jehangir
Car: 1992 Infiniti Q45A
Okay, Now I'm officially ticked. I put the upperlinks in. And you guys were correct. It was a snap. But I still haven't resolved my initial problem. I have been having a "clunk" sound when I go over bumps. It sounds like it is comming from the front passenger side wheel. I also feel it in my floor boards. But the steering wheel still feels nice and tight. Very frustrating.Has anyone else had similar issues with their active G50?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
like i said earlier, replace your sway and tension rod bushigns and go from there....
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Sway bar frame bushings first.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If after all that, time to check the spring seats and shock assembly rubber.
Do the cheap stuff first.
Jehangir
waiting on the bushings from joe. they should be here this weekend. other then having the tension rod bushing pressed in; any other tips for me to make this job easier....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Get an FSM. You don't tighten the links until the car is on the ground, suspension loaded.
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
maxnix wrote:Get an FSM. You don't tighten the links until the car is on the ground, suspension loaded.
Dumb question. I have a rubbery sounding noise coming from the right side (sounds more like the rubber for the strut) that didn't go away after replacing the upper links. You're saying that you must tighten the upper links when the car is on the ground? How is that possible with the wheel on?
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
check rear sub frame bushings
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Careless terminology by me.
The tension rods.
Links are torqued to 100 ft. lbs. (?) before wheel is mounted.
