suspension noise. help
youngcoke
i hear a clanking noise sound like metal and sometimes like its hitting rubber. i sometimes hear it in the rear.every time i hit a bump i heared the noise, so i thought it was the rear shocks. i replaced both rear shocks, and dont hear it as offten but i do still hear it somtimes on bumps.any ideas what it could be?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
can you recreate the noise by bouncing the corners of the vehicle?
Its most likely going to be a bushing issue, either way sway bar bushings or something like that.
youngcoke
their is a sway bar in the rear?
OBX4x4
Car: '00 Pathfinder LE 4x4, modded
yeah lol, it's above the axle & diff
tmorgan4
Car: 2000 Nissan Pathfinder
Metal clanking noise? Make sure your spare is tight up against the bottom of the vehicle. It hangs on a chain and I've had it make all sorts of noise when it decides to come loose.
