slyedog240sx »
https://forums.nicoclub.com/slyedog240sx-u57038.html
Sat May 02, 2009 8:07 am
I installed some adj tension rods this winter from courtesy nissan.Now that it is nice i got the 240 out.When the suspension is under a load i am hearing a popping sound.Everything is tight and aligned in spec.All the front chassis is new, tie rods, ball joints, sway bar links and bar to frame bushings, rack bushings, struts, mounts, springs.Is this noise typical it isn't bad but enough to be annoying.Does it when turning ,or anytine the suspension moves up and down.Any ideas?
