centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Mon Aug 14, 2017 2:04 pm
Well, the bulk of harshness would be the coilovers I think. And you already bought those, so you might as well install them, imho. If you don't like them, maybe try a softer spring rate, but the same dampers. All the bits you list just need a set of bushings to complete the package. I guess, stay away from solid aluminum type bushings. Maybe look for NISMO hardened rubber bushings instead of the typical urethane ones (Like ES). Though, bushings don't make a big difference in harshness, they add up with all other bits. Same for low profile tires. The lower the profile, the harsher the ride. You could consider going with 17" instead of 18". That would put some more shock absorbing rubber between you and the pavement. It would save you money on replacement tires over the years to come (17" tires are typically cheaper than 18" tires). The sway bars will flatten the ride (less lateral roll), but I'm not sure how harsh that will make a rough road feel. I suppose you could go back and forth between those and your stock bars to feel it out. Harsh ride is really a personal preference thing, so it's tough to say what would be too harsh for someone else. Maybe put on all the stuff and see what it feels like, then adjust.
