allenms240 »
https://forums.nicoclub.com/allenms240-u128640.html
Thu Aug 04, 2011 5:22 am
By the time you are done finishing replacing all those bushings, you're not going to want to do it all at once. It's such a PITA and takes forever to do them all. I did mine over a few days because it was my DD as well. I did a few bushings, put the car back together, drove it to work, then broke it down again on a day off.
You really only need RUCAs if you're going to be low. This is my DD and I have coil-overs, RUCAs, and toe rods. I figured I might as well save the life of my tires and buy toe rods. Definitive get an alignment after you're done installing installation pieces/ Just make sure you're at the right height for you, because if you adjust it, the alignment will go out again, and you've just wasted ~$65.
