First, turn off the caps lock
Calmini, 4x4parts.com, Rancho, etc. all make a 2.5-3" lift for your truck that includes longer upper control arms so you can get the lift via a torsion bar crank.
Trailmaster made a 4" drop bracket lift for hardbodies that could be combined with one of the lifts above for about 6" of lift, but your stock steering won't be up to task. You'll need a steering solution, of which there are few available. Hoohaa centerlinks (an ad for them can be found on my website,
http://www.nissan4wheelers.com) and Calmini (
www.purenissan.com) both sell aftermarket steering setups that address the junk stock centerlink on a lifted Nissan.
Combining these two lifts and getting a steering fix is going to be expensive. Ask yourself a few questions:
- Are you doing this for looks, or for offroad performance?- What size tires do you have in mind?- Can / do you do all your own work on the truck?
If you have some fab skills, consider a solid axle swap if you're going for pure offroad performance. If you don't do your own work on your truck, I'd honestly consider leaving it stock, because a lifted IFS will require periodic tinkering, and shop time gets awfully expensive.
