ImStricken06 »
https://forums.nicoclub.com/imstricken06-u194849.html
Sun Jul 29, 2012 4:57 pm
#1 they will make the ride much rougher, unless you replace the shocks, because they won't let them flex and will eventually destroy the shocks. They can make it ride slightly worse because the control arm angles will be a little steeper.
#2 If you get shocks that are too long they won't be able to expand enough and will bottom out over bumps, which will also destroy the shocks, as they aren't designed to be bumpstops.
#3 to tall, and it might start tugging on the rear propeller shaft.
If you ran a 2" MAX spacer lift and 2" bumpstop extensions you'd probably be fine. just dont go air-borne, or even close to it over rail-road tracks. you'd place serious stress on joints, since you'd be taking away height extension from the system for the lift.
