Hey Erik, welcome to Nico!
If you're looking at having a significant load more often than not, then medium or heavy-duty coils will do the trick and keep the ride at the proper height. However, if you'd like to keep the ride nice during the week but still haul stuff around on the weekends, then airbags are probably the preferred route. A lot of members have used and had good luck with
the AirLift 1000. It lets you adjust the pressure in them to raise and stiffen the ride when you're hauling. Take a look and see if it sounds like what you're looking for!
The only thing I'm uncertain of is if the bags would maintain your 2" lift. Maybe post in the linked thread to see if anyone there has experience with that. I'm guessing if you use a spacer lift it won't be an issue.
For more general lift-related questions, check out the threads I link to
in this post.
Good luck!
