so my caster is way off on my passengers side somewhere around 2 inches. im not noticing any bends in anything or frame damage. it all looks straight. the only thing that looks suspect is a patch welded where the cross member mounts to the subframe. but i can imagine that is causing the main part of the issue. i got the caster better by removing the bushing on the tension bar and moving it to the front side as a spacer. i haven't measured the length of this bar but im wondering if its the wrong one that was replaced.
it looks like it may have hit a huge pothole or a curb at sometime as the back wheel has toe issues and looks like the trailing arm mounting point is slightly bent.
im looking at this
https://store.garagistic.com/z-car-tc-r ... Ah0c8P8HAQ
but im sure there is a better option. but if not will this even work correctly?
