merlinq2 »
https://forums.nicoclub.com/merlinq2-u171090.html
Wed Jul 18, 2012 9:55 am
I have had the same issue, lowered the car, and then developed the After Shock. Took it to the dealer had it aligned and the issue was dramatically reduced. It is still there.
I think the M35x does not like to be lowered, the initial spring; strut shock set up was designed for settling down the car based on the extra weight associated with the awd.
I did not have any of these problems prior to the drop; the car was smoother, handled way better and was nicer to drive. Now with the stiffer springs, I spend more time trying to avoid bumps etc.
-Going back to the stock set up.
I have three different shops look at the struts and all give them the thumbs up. They tell me to wait until I get the bouncy front end before I spend the money.
I agree that a certain mileage the struts will go, they are engineered to break down over time. In my case the springs did more harm to the car than good. The looks were improved tenfold; however, the ride was compromised.
After some research into asphalt and heat I found that the oppressive heat we are having in Southern Ontario is wreaking havoc on the roads, they are breaking down and more and more road surfaces are rough bumpy; pot holes are soon to follow.
By the way, taking a tech around with you is useless; a lot of them don't drive the M's so to them they have no idea what to look out for.
My wife can drive my car and not report anything, I drive it I hear, see and feel everything! Why would a tech be any different?
Let us know what you end up doing, once I revert back to my stock set up I will let you know what I found
Not sure why you would need to replace the sway bar links; the sway bar bushings I can see the links – not so much.
