suspension issues
silk240
Car: '92 white 240sx coupe w/ blacktop sr20det
i drive a 92 s13
alright the problem i am noticing is that when i go into a turn fairly hard the car rides smooth then all of a sudden there is a quick jerk then back to riding fine. it seems to only do this on left hand turns. i had just replaced the inner outer tie rods about 7 months ago and replaced the tension rods. its had an alignment but maybe its been knocked out of alignment now. looking for some insight on this issue.....
gingerbredman
Car: 93 SE hatch, ~260k miles on the clock, 15" Enkei 92s, still stock. 2009 Sonata bouncing on Eibachs.
does it sorta pop when you get to going straight again? ever since i swapped my sportlines for my stock springs, they seem to kinda lock up if i turn all the way in one direction, it'll pull hard in that direction until i hit a bump and i reckon the spring or whatever reseats and the car drives straight again. beats me, i was thinking maybe bushings, or ball joints??
silk240
when im backing out of the drive way and turn the wheel sharpe this is a pop sometimes. but the jerk im talking about happens when im driving through a corner at an aggeresive speed.
silk240
anyone else got some insight??
h.240
Car: 1991 240sx hatchback
I would start by checking for worn ball joints, and strut mounts.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
H.240 is rite.....look for ball joints..worn bushings....and inspect your bearings man..just do a wjho close inspection..motor mounts..everything under the front...allso..jack the car up and look at your steering rack..see if there is any damage..lots of places to look..keep us posted and good luck.
silk240
yeah going to try and do some investigating this weekend, thanks for all the insight
