suspension install help
popogto
how difficult is it to install KYB AGX in my house? what kind of tools do i need? or should i just take it to a pro?
and those KYB AGXs fit with tein S.tech springs.......................right..?thanks
ziggy682
Car: 1991 240SX Turbo
It's pretty easy if your mechanically inclined and have a decent set of tools. You will need to buy/rent a spring compressor from an auto parts store. Sometimes the top nut that holds the strut assembly together just likes to spin with the strut shaft when you try to remove it. An impact makes quick work of it. There's really not much to it.
