JC87HB wrote:2wd HB have a front Sway bar?
yes sir they do...
seang wrote:As long as there is no binding, then the worst that could happen is faster end link bushing wear. IDK for sure. I guess get some grade 9 (if you must, you can try grade 8) bolts, assemble the washer/spacer/bushing stack, and torque 'em on down.
i was going to use grade 8 for sure it would suck to do all the work and have it be in vain cause the bolts fail..
i think ill play around with it next week and let you guys know the results
