BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Mon Oct 06, 2014 4:06 pm
if you have the electronic suspension you should just go ahead and buy the rebuild kit. The only other real option you have is to do a full coilover setup which will end up costing about the same. However, if you want it stiffer or lower the coilovers are you best option...if you rebuild your sentenced to Infiniti parts which you can get cheaper from everythinginfiniti.com who is really Scottsdale Infiniti.
