Suspension help
nametakennow
Car: '06 MINI Cooper S
I'm playing around with the idea of trying to begin to balance out my handling. My car came with the stock Nissan front upper tie bar, and I was thinking a rear bar of some sort would be nice to balance it out. Who makes them for non-SE-R Sentras, and does it really matter, shouldn't they fit all? This rear sway bar, for instance...
Exar-Kun
Car: 2005 350Z
contact SWA, it *should* fit. you may want to check to see if the front sway on the non-Se-R's is smaller, if so, i would see if you can use the Se-R front bar to balance the roll stability of the car.-chet
nametakennow
They emailed me back and said they didn't know... arrr!
