Suspension Help!
JC87HB
Car: 1987 Nissan D21 HB
Ok so i rolled into a ditch at about 2-8 mph (1st gear clutch in) and got stuck. Got pulled out by the front hooks. Well now my rear Axle shifted over to left just a bit. Noticeable by looking from the rear. Does anyone have any ideas of what could be wrong? O and it drives fine... pulls to the right only on acceleration with the wheel straight. In neutral it goes straight with the wheel straight.. Anyone have any ideas on whats up?
seang
Car: Ford Fiesta ST
It could be your leaf spring bushings. If they are the culprit, get poly ones from an aftermarket maker, because stock ones are more expensive.
JC87HB
kk. When i get my 30'' tires on monday can i just get them to align the rear axle or rather "Center" it?
seang
Car: Ford Fiesta ST
Not with sloppy bushings.
Andy4106
Car: 91 s13
08 frontier
if it only pulls when you acl, then its not your springs. but could be why its off but not why you pull. id guess drive shaft at the moment. re run your leaf springs then look at the shaft
JC87HB
I mean its only to the left likek 1/4 to an 1/2.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
It's not the driveshaft.
It's either slop in the bushings causing the springs to walk over, bent front spring eye mounts, or bent shackles.
JC87HB
Thanks so much guys. When i get my 30s i am putting a shackle kit onn and cranking T bars to even it out. When i put the Shackles on ill replace the leaf spring bushings with new ones. I appreciate all the help! Sams should be able to Align/center the axle right?
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
If nothing's bent, it'll put things right again.
JC87HB
Cool. Hopefully nothings bent. I went into that dtich slow. it wasnt even a huge ditch just enough to get my (225/60/R15) stuck lol.
