I'm ok with stiff, I'm already riding on some pretty stiff suspension. I like it that way though, I get more feel for the road.tramp_drift240 wrote:may be too stiff for his likings, at 10/8kgmm.
but thats up to OP.
theyve got a DAMN good price for a great product, im actually contemplating getting a set to compare with my Tein superdrifts.
Can you explain "8 and 6" please?Space Monkey wrote:Tramp, PBM will make custom ciols for the same price. He could get 8 and 6 if he wants. But they also let you know that their coils are build with a different tech than most and perform "softer" to the feel in the ride but still perform like "stiffer" coils.
Earlier Tramp mentioned that the coils are made with 10kg front & 8kg rear. I believe this refers to the force keeping your tire on the ground. The higher the number the stiffer the coils are going to be and the more your going to feel every little bump you run over and makes the ride uncomfortable. This is from PBM.kornmanz wrote:
That should answer your question.kornmanz wrote:
We get a lot of questions from S-Chassis owners looking to buy our competition coilovers for street use like this ..."Is there a way to order a set with 8kg/6kg spring rates? I am going to be using them on my daily driver so I don't want them to be super stiff." "Is there a way to order a set with 8kg/6kg spring rates? I am going to be using them on my daily driver so I don't want them to be super stiff."
The short answer is yes, you can order them with 8/6 for no additional charge, it will be about 8 weeks till they come in. The short answer is yes, you can order them with 8 / 6 for no additional charge, it will be about 8 weeks till they come in.
My advice is that you should not buy our coilover if you are looking for a plush ride. My advice is that you should not buy our coilover if you are looking for a plush ride.I would however recommend buying them at the original specification if you desire an aggressive coilover that is streetable, just adjust it to full soft. Most of our customers daily drive these competition coilovers, and they all say the same thing over and over in reviews: "Its not as bad as you'd think on the street". They are not as harsh with 8/10kg's as say a GP sport coilover with 9/7kg's because of our unique damper. Our damper has relatively little compression damping allowing the larger rate spring to compress more easily upon impact, yet they have an extraordinary amount of rebound damping to control the bounce you may expect with a conventional damper. I would however recommend buying them at the original specification if you desire an aggressive coilover that is streetable, just adjust it to full soft. Most of our customers daily drive these competition coilovers, and they all say the same thing over and over in reviews: "Its not as bad as you'd think on the street". They are not as harsh with 8/10kg 's as say a GP sport coilover with 9/7kg' s because of our unique damper. Our damper has relatively little compression damping allowing the larger rate spring to compress more easily upon impact, yet they have an extraordinary amount of rebound damping to control the bounce you may expect with a conventional damper.You can order an additional set of 6kg springs for $160 shipped to the USA at any point you feel its necessary to switch, but for the record the only people who think they need 8/6 are people who dont already own the coilovers. You can order an additional set of 6kg springs for $ 160 shipped to the USA at any point you feel its necessary to switch, but for the record the only people who think they need 8 / 6 are people who dont already own the coilovers.
For your peace of mind, nobody has ever replaced a damper due to high mileage daily driving or track abuse other than crashing. If for some reason you should encounter a problem with your damper, we sell 100% brand new replacements for $100 each which costs less than other brand's rebuild, and boasts the advantage almost no down time. -Dan at MAX USA For your peace of mind, nobody has ever replaced a damper due to high mileage daily driving or track abuse other than crashing. If for some reason you should encounter a problem with your damper, we sell 100% brand new replacements for $ 100 each which costs less than other brand's rebuild, and boasts the advantage almost no down time.-Dan at MAX USA
thats true, but still, im sure some people are less than satisfied with their double digit spring rating.Space Monkey wrote:Tramp, PBM will make custom ciols for the same price. He could get 8 and 6 if he wants. But they also let you know that their coils are build with a different tech than most and perform "softer" to the feel in the ride but still perform like "stiffer" coils.
Thanks a lot man, Very informative and I understood the 8 and 6 right away lol.Space Monkey wrote:
Oh yeah I'm pretty sold on the PBM coils.tramp_drift240 wrote:im also very interested in all of their suspension arms, definitely worth checking out, Kornmanz.
