WAAAAAY over kill. You said you're looking for better handling as a daily driver, and the occasional drag. Youre talking an all out grip/drift setup. No need. No sense spending $3K on suspension to daily drive a stock motor. If you have future plans, then go for it. All you really need/should want, is the Energy suspension bushing kit, and a spring/strut setup. With the Bushing kit you're going to get your Tension rod bushings (which are always bad), and stock sway bar bushings.sausagelinks98 wrote:Hey, I need some suspension help. I posted hear since I though more people would read it then in the suspension section since its slower so if this can stay here...ya. OK well I need some help. I plan to upgrade my suspension on my s13 and I was wondering if you can help me. This will be daily driven and taken to the drag strip once and awhile. I also want to attend a few drift events to learn a little. Here my thing. What are the suspension components I'll need. I've over whelmed my self. I want to use the nismo coil overs btw. So my question is what will I need to get better handling and not just add coil overs, I want to go a little beyond. I hear I'll need like upper control arm and stuff. Can some one help me come up with a good setup.Heres what I though mite be needed but its a little much-
Nismo S-Tune Coilovers Sway barsFront/Rear strut braceHKS Kansai Front Lower Arm Brace barIntensePower Adjustable Rear Upper Arms Kazama Tie Rod EndsKazama Pillow Tension RodBattle Version Rear Forward Traction Link Arms Front and Rear SPL front endlinks SPL pro front lower arm Replace all bushings with Energy Suspension bushings
Yea, yea I know what they are (I work for Nissan). I think I may have had a buzz going before I was heading out, and didnt real the whole line. My bad! I just saw all the other adjustable stuff and was like WOAHSeVa-S13 wrote:Looks to be a good list for a streetable car with occasional track time.
I'm not sure NISMOdrift240 knows what S-tune's are but they're quite conservative and streetable, but are basically a matched spring/strut combo and really can't compare with real coilovers. But hey, not everyone wants to be impractically low and have a crap ride on the street so .
Edit: Oh, and you don't have FUCA's, only RUCA's.
