suspension forum is dead will try here....
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
Ok I installed my nismo power brace. i noticed that I now have very little space between the brace and my sway bar. I was wondering if any has the power brace and aftermarket sway bars?? If so what sway bars are you using?? If I cant change the sway bar I guess I will install strut bars instead
Thanks again in advance
Jason
White Comet
Car: fc, s13 and mazda6, Sierra
i can not be of any help since i have neither but at least u know this forum isnt dead like suspension
Dattebayo
The suspension forum is dead because its fricken late.Also:
d!ck wrote:I'm not the only one who has been noticing that a lot of questions that belong in the suspension, wheel and tire, and engine subforums are being placed in 240sx/Silvia gen chat. Technically, yes there are more views/replies per thread created in here than in the other sections, but why do you think that is? That's right; the reason you can't get a quick answer in the subsections is because YOU DON'T POST THERE ENOUGH!
Source: zerothread?id=274062
You are defeating yourself. And You will probably get mauled by d!ck....
E7-S14
Car: ess 14 foo!
Dattebayo wrote:The suspension forum is dead because its fricken late.
I was just about to chime in with this factthe suspension forum is not dead.. its late.. that just might contribute to your problem
and you lie.. you did not try this in the suspension forum..im in the suspension forum all the time.. and you tried no such thing..
White Comet
i think he's right. i searched for threads created by hybrid_flyer and there was no such thread anywhere
adrianfromthecastle
Car: 1992 Nissan 240sx
there should be no clearance issues. It should be the same fitment as oem, cuz they arent beefier or anything. The sway bar D bushings are supposed to rest on them. Loosen your endlinks to give it play when you're tryin to install it
Drewster
Car: 1991 240sx
strut bars and sway bars do different things
hybrid_flyer
true i did not try this topic in there but i did try another topic and got little response, but got a larger response in the general forum
hybrid_flyer
bumpy bump
94_240sx
Car: 94_240SX
I have Nismo power brace with Progress sway bar, and I have no clearance issue. They are close to each other, but when the sway bar moves, it'll never touch power brace.
adrians_s13 wrote:Loosen your endlinks to give it play when you're tryin to install it
That's exactly what I did. I swung sway bar around before I installed endlinks to see if it touches anything, and it didn't. You don't have to worry.
Modified by 94_240sx at 7:56 AM 8/29/2007
babowc
Car: 240sx
^Very nice and clean.What adj. arms are those?Kazama for the tie rods?
94_240sx
Car: 94_240SX
babowc wrote:^Very nice and clean.What adj. arms are those?Kazama for the tie rods?
Thanks man. They are Kazama tension rods and tie rod ends.
hybrid_flyer
94_240sx wrote:I have Nismo power brace with Progress sway bar, and I have no clearance issue. They are close to each other, but when the sway bar moves, it'll never touch power brace.
how much thicker is the sway bar over stock. I was looking to get whitelines (not sure at the moment how thick they are) If the progress bar is the only one that'll fit that makes that decision on what bars to get a lot easier.
94_240sx
Car: 94_240SX
Both of them are 27mm. Check this site. It's very informative.
http://en.wikibooks.org/wiki/N..._Bars
This is the endlink that comes with Whiteline sway bars. They tend to bind.
You can buy these end links from PDM. Available for only for the front and price is $83.25 per pair.
These end links come with Progress sway bars front and rear. I did a lot of research and ended up getting Progress bars. Good quality, perfect fitment, 3-way adjustable front and back, and most of all, come with nice end links. Customer support was awsome too.
Check this thread. Whiteline sway bar couldn't clear Yashi Factory core support guard, but Progress bar did.zerothread?id=268894
I highly recommend Progress sway bars.
Modified by 94_240sx at 8:41 AM 8/30/2007
hybrid_flyer
thanks 94_240sx that was extremely helpful. It looks like I will be getting some progress sway bars in the near future.
