Wheelzs3 wrote:you lower the car on factory struts your putting more weight on the struts correct? also the shaft in the strut doesn't travel as much as it would if you had your factory springs on right? How about I sum it up like this if you want the factory ride with a little bounce then get springs if you want a more stiff ride without the bounce get Coilovers!!! How about that?
To answer you question directly, the weight remains the same on struts with lowering springs. It is true that you have less travel on your dampeners. I have no additional bounce that can be felt whatsoever. I do however have better handling, equal ride qualty, and improved looks. So much so that I drive now just for the hell of it. The car is so smooth but handles so well. The car loves bumps on turns and proves this by maintaining contact to the road on all (4) corners. We are talking supple ride quality with attitude.
Coilovers are GREAT! But, be prepared to spend $2500 before install and another two hundred more to truly take full advantage of them (should be professionally tuned). For they must be tuned properly.
This what the experts say..."even if you’re a seasoned coilover user as there exists a lot of misinformation about coilovers. This is because, more than with any other style of shock & spring, the coilover user is presented with almost limitless options regarding setup. Mounting, valving, spring rates, spring lengths, gas pressure and more are all completely in the hands of the installer and can be easily changed from one extreme to another. When those hands are expert – the result is phenomenal performance. When those hands are not so expert – the unfortunate result is that we novices really just have a huge amount of rope with which to hang ourselves. Instead of a huge number of ways we can tune, we are faced with a huge number of ways we can get it wrong, and sometimes badly wrong at that."
With springs, companies like "Eibach" have done the best they can to optimize their spring with existing OEM shocks/struts--takes the guess work out of it.
Ironically if you go to other forums in regards to coilovers, what you mostly hear is "my ride quality is bad/stiff, my car feels bouncy, but she handles great".
Again, coilovers are wonderful, but there are far too many weekend warriors severly compromising/degrading the coilovers ability to do it's job correctly. Tuned properly, you can have your cake and eat it too...but at what cost?
