suspension creak?
Streets_of_Fire
Hello. I had a shop install stock springs + dampers which i bought of a local guy (it was all assembled) anyhow, during the install the front right strut was kinda bent at the top (shop guy said maybe i was dropped) and said it was nothing major and just took pliers and bent it back. today i noticed that that side gives a creak when i roll over high speed bumps. what could it be? thanks
EazyBreazy
wait what, what part did he bend with pliers, nothing of importance can be bent with a simple set of pliers
Streets_of_Fire
the top portion of the strut where the 3 bolts are. the 3 bolts wouldnt align and when he looked at them, the top plate was kinda bent, so he straightened it and put it back in and the bolts aligned.
94_240sx
Car: 94_240SX
My stock strut used to do that when it was cold in the morning. Is yours doing it all the time?
Streets_of_Fire
to tell you the truth, it usually is cold, butit seems to happen through out the day, i will observe it, i just dont want to find out i have a bad shock or something that is bending my frame or something crazy like that, thanks though so far
Streets_of_Fire
also, 94-420SX does yours still creak when its cold? did you find out why?
