Postby
Korben15 »
https://forums.nicoclub.com/korben15-u258265.htmlSun Mar 26, 2017 6:30 pm
Ok, I've got a 2006 M35 with all the stock upgrades, 150k miles. I need to purchase new end links for my front sway bar. What other bushings or end links should I buy to replace because they're probably worn out? I'm looking to restore the ride to as close to stock as possible. I've already replaced the rear shocks, front struts and mounts.
Postby
midnightclub619 »
https://forums.nicoclub.com/midnightclub619-u234840.htmlMon Mar 27, 2017 7:45 pm
you should also take a look at the stabilizer links and check those to make sure they are still good. there is a how-to with part numbers. i did that about 15k ago and still doing good
Postby
Ilya »
https://forums.nicoclub.com/ilya-u159401.htmlMon Mar 27, 2017 10:01 pm
midnightclub619 wrote:you should also take a look at the stabilizer links and check those to make sure they are still good. there is a how-to with part numbers. i did that about 15k ago and still doing good
