DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Mon Aug 01, 2016 5:48 am
Welcome!
It is true for coilovers that you need to replace the Front Upper Camber Arms (FUCA), Rear Upper Control Arms (RUCA), and tension rods to adjustable parts, to allow the lowering effect of the coilovers. Failure to do so will ruin the OEM parts if not already well-worn as most are in the 80-100K mile range.
Simply replacing shocks in the OEM struts is the normal repair an will not require replacing those parts with adjustable parts, but you may want to inspect those parts due to age and the fact the rest of the suspension will be worn as the shocks were, possibly (probably) the springs will be sagging causing excessive camber and with the FUCA's well-worn as well, adding to the camber effect.
Powertrix offers all needed parts and can be had at pricing savings especially if all purchased together, a personal call to Charles at Powertrix (HIGHLY recommended) is a fun learning experience as you will find. If needing to take time to purchase parts you COULD run the coilovers at OEM height/settings and avoid the immediate need for adjustable bits, but those parts MUST be purchased as well for best overall experience and to lower the car.
Good Luck!
