jmauld »
https://forums.nicoclub.com/jmauld-u6294.html
Mon Oct 25, 2004 11:37 am
Okay, Let's clear some things up.
A Harmonic Damper has absolutely NOTHING to do with the balance of the crank. The point of that rubber piece is to dampen the effects of the power stroke. Does the KA need to have it in there? I'm not answering that, because I don't really know. The engineers who built it seem to think so. Also, when I removed mine I started getting a noise at certain RPM, and I also blew my water pump right afterwards. With that said, I still have the undamped pulley installed, and don't plan to remove it.
For an example of this, grab a pen and thump it. Then stick a big eraser on the end of the pen and thump it again. You should feel the difference.
The flywheel has nothing to do with weakening the electronics.
