suspension advise
calypso699
Hi. I have a 1990 240 with completly stock suspension. I want to order the the front and rear upper strut tower bars from Apex. Is adding these bars to a stock suspension a good idea? I heard that it will only result in increased body roll. Is this true? Any help is appreciated. Thanks in advance. Mitchell
nolaws4evr
Car: cruisin tha streets of Huntsville, runnin down hondas, tryin to get money out of my insurance comp.
first off your postin in the wrong section, go to the tires/wheels/suspension section and search before you get flamed. Now, to answer your question, stbs are designed to reduce body roll and make your car more ridgid, there is no way they are going to do the opposite. Apex is a great company and I would recomend you get those bars, they will help.
calypso699
ok umm sorry thanks for the help. mitch
yeswepromise
might i suggest stabilizer bars first
pball
Get both at once, swaybars arent that much more expensive than STBs (at least not as mods go..), and the package is probably the best bang-per-buck improvement you can make.
calypso699
ill check out the stabilizer bars. thanks!
