elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Thu Sep 17, 2009 8:51 am
All the bushings should be compatible. LCA and tension rod for sure, sway bar links and bushings are different... All the rear suspension bushings (outside of sway bar) are the same.
Not sure on machine shop charges, it shouldnt be a whole lot... As long as they have the right size dowels it shouldnt be a big deal...
Note that they dont make upper control arm bushings, and you cant press out the stock bushings anyway.
