tyrodtom »
https://forums.nicoclub.com/tyrodtom-u133407.html
Thu May 07, 2009 2:07 pm
I've been circle track racing a 90 240SX since 2003, 23 wins so far. All of a sudden a problem has occured, the car cuts out at full power, after about 5-6 seconds, stays powerless for about the same amout of time, then comes back full power. Will repeat this endlessly as long as i'm willing to drive it.
It does this in 3rd gear, will only do it at the track under full thottle. If I put the car in 4th, it still does it, but at longer intervals. I can't similate the condition in neutral, and don't dare drive it on public roads to test it since it's a full race car, unmuffled, caged, windowless, decaled, etc.
I've tested fuel pump pressure, but not under full load. When the car shuts down, it's instant, no backfire, just completely goes away, then just as suddenly comes back to full power. It's like something suddenly is shuting the injectors off, and I would think only the ecu could do this. I've got a FSM, and have run every test I can think of, the computer will not do a valid self check, so I suspect more is wrong with it. The car is a completly stock KA24E, with all smog equipment removed, and has run fine for years this way, until all of a sudden this problem appeared.
Any thoughts on something I might have overlooked???
