Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Dec 08, 2016 6:56 pm
Hello and welcome to NICO!
I filled out your survey, and good luck on your project. I have a few comments to make.
Most of your designs look a bit clunky to use with a jack. The best design that would work, in my opinion, is the second design. The first design would have issues with most jacks as it would have to straddle the bottom bar, and it would be cumbersome to set up and use. The third design is not a favorite of mine. I tend to not use the weight of the vehicle as opposition force. Multiple reasons on this, I've had bushings/bearings fight quite a few tons. They would have easily moved a car. It would be better to use clamping force than vehicle weight. The last design, while unique, looks excruciatingly cumbersome. I think you'd be losing a lot of force trying to keep the base planted rather than have it translated through the lever.
Look at a lot of the press designs that already exist. You have your big presses that push into a base of some form. They work fairly well. Bushings/bearings will use screw clamps to drive into their races. The big thing when you begin a design is to find if there's a unique solution to a problem that has multiple methods to perform the task and then fill in the gaps. I wish you well on your project, and I think you've got some solid ideas so far. They just need to be thought of on a more practical, general scale. Don't design a jack method that relies on a specific jack. Make it work with a multitude of jack designs.
