surging under boost
quiksilvia
Car: 95 s14 se
ive had this problem before but it just went away. since last night, raced a srt-4 for the hell of it, ive developed a ticking noise sounds like a valve tap, and all cylinders are firing. also when im pushing boost, it goes to 7 psi and its boosting, but the its like the boost isnt getting to the motor, and it kinda surges forward. make sense?
SpeedRacer1
Car: 1990 240SX, G35
If the ticking is at all RPM's and you do not think its the coils firing then it is probably the hydraulic valve adjusters. They will make a sound, and need to be replaced when you start to notice your idle going weird. As for the surging boost I dont quite understand what you are talking about.
quiksilvia
Car: 95 s14 se
the boost is there but its like the boost isnt getting to the motor all the time. and it gets to the motor in surges, im going to a shop tomorrow to see if they can make sense of it
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
So do you mean, youll be driving and all of a sudden youll get a quick surge for the boost even though it should have beent here the entire time?
quiksilvia
Car: 95 s14 se
its off and on through the gear
SpeedRacer1
I had a problem similer to this, turned out I was just accelerating really slowly. I solved it by pushing the gas harder. Doubt that helps.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
off and on through the gear? no clue what it oculd be
quiksilvia
Car: 95 s14 se
i mash the pedal, thats not it
f150intally
could the surging be a boost leak?
quiksilvia
Car: 95 s14 se
i found it, one of my spark plugs is not in all the way, i think the threads might be stripped, ill keep you informed as i figure it out
theronin
:doh:
quiksilvia
Car: 95 s14 se
it jsut worked itself out, i screwed it in and its ok, d'oh is right
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
im glad you got that one figured out before you took it to the shop!
theronin
:doh :doh
