RMiller »
https://forums.nicoclub.com/rmiller-u12169.html
Wed Nov 24, 2004 9:12 am
I'll bet it's something simpler. You might have a boost leak. This would explain the surging and the stumbling. MAF problem would not explain surging. If you have a leak, the wastegate will not open when it should because the pressure signal will not be a true 7psi or whatever. Also, if there is a boost leak the MAF will measure air sucked in by the turbo and the computer will deliver lots of fuel, but if air is leaking out before it gets to the engine, you will run rich, causing stumbling.
I have had intercooler pipe couplers pop off tons of times, and if I'm not careful, my turbo will spool beyond its efficiency range, and cause surging. It's also almost impossible to drive, it runs so rich. Your stumbing problem isn't as bad and that may be because you have a smaller boost leak.
What is your idle at? If it is higher, or if you had to adjust it quite a bit to lower it to where it should be, the leak will be after the throttle body. If you always had normal idle, it may be before the throttle body.
